/v1/models endpoint.
Perplexity provides third-party model access with transparent token-based pricing, consolidated on a single bill. See Agent API Models for the full list and current rates.
Prerequisites
Install the Perplexity SDK:pip install perplexityai
npm install @perplexity-ai/perplexity_ai
Get your Perplexity API Key
Navigate to the API Keys tab in the API Portal and generate a new key.
export PERPLEXITY_API_KEY="your-api-key"
Why Multi-Provider?
| Benefit | Details |
| Single API key | Access OpenAI, Anthropic, Google, xAI, and Perplexity models without separate accounts |
| Transparent pricing | Third-party model usage is charged at published model rates |
| Unified format | Same request/response format across all providers |
| Built-in fallback | The models parameter tries providers in order until one succeeds |
| Tool compatibility | web_search, fetch_url, and custom functions work with all models |
Available Models
Use the/v1/models endpoint to discover all available models dynamically.
import requests
import os
resp = requests.get(
"https://api.perplexity.ai/v1/models",
headers={"Authorization": f"Bearer {os.environ['PERPLEXITY_API_KEY']}"}
models = resp.json()["data"]
# Group by provider
providers = {}
for model in models:
provider = model["id"].split("/")[0] if "/" in model["id"] else "perplexity"
providers.setdefault(provider, []).append(model["id"])
for provider, model_ids in sorted(providers.items()):
print(f"\n{provider}:")
for mid in model_ids:
print(f" {mid}")
const resp = await fetch("https://api.perplexity.ai/v1/models", {
headers: { Authorization: `Bearer ${process.env.PERPLEXITY_API_KEY}` },
const models = (await resp.json()).data;
// Group by provider
const providers: Record<string, string[]> = {};
for (const model of models) {
const provider = model.id.includes("/") ? model.id.split("/")[0] : "perplexity";
(providers[provider] ??= []).push(model.id);
for (const [provider, ids] of Object.entries(providers).sort()) {
console.log(`\n${provider}:`);
for (const id of ids) console.log(` ${id}`);
curl -s "https://api.perplexity.ai/v1/models" \
-H "Authorization: Bearer $PERPLEXITY_API_KEY" | python3 -m json.tool
| Provider | Models | Best For |
| OpenAI | openai/gpt-5.6-sol, openai/gpt-5.6-terra, openai/gpt-5.6-luna, openai/gpt-5.5 | General reasoning, code, analysis |
| Anthropic | anthropic/claude-opus-5-5, anthropic/claude-sonnet-5-5, anthropic/claude-haiku-5-5 | Long context, instruction following |
google/gemini-4-hydrogen, google/gemini-4-argon | Multimodal, fast inference | |
| xAI | xai/grok-4.7 | Fast responses, conversational |
| Perplexity | perplexity/sonar | Search-grounded answers |
Routing to a Specific Provider
Use themodel parameter to target a specific provider’s model.
client = Perplexity()
# Route to OpenAI
openai_response = client.responses.create(
model="openai/gpt-5.6-terra",
input="Explain the difference between TCP and UDP.",
max_output_tokens=500,
print(f"OpenAI: {openai_response.output_text[:200]}...")
# Route to Anthropic
anthropic_response = client.responses.create(
model="anthropic/claude-sonnet-5-5",
print(f"Anthropic: {anthropic_response.output_text[:200]}...")
# Route to Google
google_response = client.responses.create(
model="google/gemini-4-hydrogen",
print(f"Google: {google_response.output_text[:200]}...")
import Perplexity from '@perplexity-ai/perplexity_ai';
const client = new Perplexity();
// Route to OpenAI
const openaiResponse = await client.responses.create({
model: "openai/gpt-5.6-terra",
input: "Explain the difference between TCP and UDP.",
max_output_tokens: 500,
console.log(`OpenAI: ${openaiResponse.output_text.slice(0, 200)}...`);
// Route to Anthropic
const anthropicResponse = await client.responses.create({
model: "anthropic/claude-sonnet-5-5",
console.log(`Anthropic: ${anthropicResponse.output_text.slice(0, 200)}...`);
// Route to Google
const googleResponse = await client.responses.create({
model: "google/gemini-4-hydrogen",
console.log(`Google: ${googleResponse.output_text.slice(0, 200)}...`);
Model Fallback Chains
Themodels parameter accepts an array of up to 5 models. The API tries each in order and returns the first successful response. This is ideal for production systems where availability matters.
# Primary: OpenAI, fallback: Anthropic, then Google
models=[
input="What are the key principles of zero-trust security?",
tools=[{"type": "web_search"}],
max_output_tokens=1024, # Required because the chain includes an anthropic/* model
print(f"Model used: {response.model}")
print(f"Response: {response.output_text[:300]}...")
const response = await client.responses.create({
models: [
input: "What are the key principles of zero-trust security?",
tools: [{ type: "web_search" }],
max_output_tokens: 1024, // Required because the chain includes an anthropic/* model
console.log(`Model used: ${response.model}`);
console.log(`Response: ${response.output_text.slice(0, 300)}...`);
Order your fallback chain by preference: put your primary model first, then alternatives in decreasing order of preference. The API returns the response from the first model that succeeds.
Comparing Responses Across Providers
Send the same prompt to multiple models and compare quality, latency, and cost.import time
import json
MODELS = [
"xai/grok-4.7",
"perplexity/sonar",
prompt = "What are the three most important design patterns in microservices architecture?"
results = []
for model in MODELS:
print(f"Querying {model}...")
start = time.time()
try:
model=model,
input=prompt,
max_output_tokens=800,
elapsed = time.time() - start
results.append({
"model": model,
"latency": round(elapsed, 2),
"tokens": response.usage.output_tokens,
"cost": response.usage.cost.total_cost,
"preview": response.output_text[:150].replace("\n", " "),
except Exception as e:
results.append({"model": model, "error": str(e)})
# Display comparison
print(f"\n{'Model':<42} {'Latency':>8} {'Tokens':>7} {'Cost':>10}")
print("-" * 70)
for r in results:
if "error" in r:
print(f"{r['model']:<42} {'ERROR':>8}")
else:
print(f"{r['model']:<42} {r['latency']:>7.2f}s {r['tokens']:>7} ${r['cost']:.5f}")
const MODELS = [
"xai/grok-4.7",
"perplexity/sonar",
const prompt = "What are the three most important design patterns in microservices architecture?";
const results: any[] = [];
for (const model of MODELS) {
console.log(`Querying ${model}...`);
const start = Date.now();
try {
model,
input: prompt,
max_output_tokens: 800,
const elapsed = (Date.now() - start) / 1000;
results.push({
model,
latency: elapsed.toFixed(2),
tokens: response.usage?.output_tokens ?? 0,
cost: response.usage?.cost?.total_cost ?? 0,
preview: response.output_text.slice(0, 150).replace(/\n/g, " "),
} catch (e: any) {
results.push({ model, error: e.message });
console.log(`\n${"Model".padEnd(42)} ${"Latency".padStart(8)} ${"Tokens".padStart(7)} ${"Cost".padStart(10)}`);
console.log("-".repeat(70));
for (const r of results) {
if (r.error) {
console.log(`${r.model.padEnd(42)} ${"ERROR".padStart(8)}`);
} else {
console.log(`${r.model.padEnd(42)} ${(r.latency + "s").padStart(8)} ${String(r.tokens).padStart(7)} ${"$" + r.cost.toFixed(5)}`);
Task-Based Model Routing
Different tasks suit different models. Build a router that picks the best model for each task type.from perplexity import Perplexity
# Route based on task characteristics
MODEL_ROUTING = {
"code": "anthropic/claude-sonnet-5-5", # Strong at code generation
"analysis": "openai/gpt-5.6-terra", # Strong at structured analysis
"fast_chat": "xai/grok-4.7", # Lowest latency
"research": "perplexity/sonar", # Built-in search grounding
"multimodal": "google/gemini-4-hydrogen", # Vision + speed
def route_request(task_type: str, prompt: str, **kwargs) -> dict:
"""Route a request to the optimal model based on task type."""
model = MODEL_ROUTING.get(task_type)
if not model:
raise ValueError(f"Unknown task type: {task_type}. Options: {list(MODEL_ROUTING.keys())}")
# Add web_search for research tasks
tools = kwargs.pop("tools", None)
if task_type == "research" and tools is None:
tools = [{"type": "web_search"}]
model=model,
input=prompt,
tools=tools,
**kwargs,
return {
"model": response.model,
"task_type": task_type,
"output": response.output_text,
# Code task → Anthropic
code_result = route_request(
"code",
"Write a Python function that implements binary search on a sorted list.",
print(f"[{code_result['task_type']}] via {code_result['model']} (${code_result['cost']:.5f})")
print(code_result["output"][:200])
# Research task → Perplexity Sonar
research_result = route_request(
"research",
"What were the key announcements at the latest WWDC?",
print(f"\n[{research_result['task_type']}] via {research_result['model']} (${research_result['cost']:.5f})")
print(research_result["output"][:200])
const MODEL_ROUTING: Record<string, string> = {
code: "anthropic/claude-sonnet-5-5",
analysis: "openai/gpt-5.6-terra",
fast_chat: "xai/grok-4.7",
research: "perplexity/sonar",
multimodal: "google/gemini-4-hydrogen",
async function routeRequest(taskType: string, prompt: string, options: Record<string, any> = {}) {
const model = MODEL_ROUTING[taskType];
if (!model) throw new Error(`Unknown task type: ${taskType}`);
const tools = options.tools ?? (taskType === "research" ? [{ type: "web_search" }] : undefined);
model,
input: prompt,
tools,
...options,
return {
model: response.model,
taskType,
output: response.output_text,
// Code task → Anthropic
const codeResult = await routeRequest("code", "Write a Python function that implements binary search on a sorted list.", { max_output_tokens: 500 });
console.log(`[${codeResult.taskType}] via ${codeResult.model} ($${codeResult.cost.toFixed(5)})`);
console.log(codeResult.output.slice(0, 200));
// Research task → Perplexity Sonar
const researchResult = await routeRequest("research", "What were the key announcements at the latest WWDC?");
console.log(`\n[${researchResult.taskType}] via ${researchResult.model} ($${researchResult.cost.toFixed(5)})`);
console.log(researchResult.output.slice(0, 200));
Combining Multi-Provider with Tools
All models accessed through the Agent API support the same tool interface —web_search, fetch_url, and custom functions work identically regardless of provider.
import json
tools = [
{"type": "web_search"},
"type": "function",
"name": "calculate_roi",
"description": "Calculate return on investment given initial cost and revenue.",
"parameters": {
"type": "object",
"properties": {
"initial_cost": {"type": "number", "description": "Initial investment in USD"},
"annual_revenue": {"type": "number", "description": "Expected annual revenue in USD"},
"years": {"type": "integer", "description": "Number of years"},
"required": ["initial_cost", "annual_revenue", "years"],
def calculate_roi(initial_cost: float, annual_revenue: float, years: int) -> dict:
total_revenue = annual_revenue * years
roi = ((total_revenue - initial_cost) / initial_cost) * 100
return {"roi_percent": round(roi, 2), "total_revenue": total_revenue, "net_profit": total_revenue - initial_cost}
question = (
"Research the average cost to deploy a 100kW commercial solar installation in 2026, "
"then calculate the 10-year ROI assuming $18,000 annual energy savings."
# Use Anthropic Claude with web search + custom function
tools=tools,
input=question,
max_output_tokens=2048,
# Keep the full conversation so every request includes the original question
conversation = [{"type": "message", "role": "user", "content": question}]
# Handle function calls
while any(item.type == "function_call" for item in response.output):
conversation += [item.model_dump(exclude_none=True) for item in response.output]
for item in response.output:
if item.type == "function_call":
args = json.loads(item.arguments)
result = calculate_roi(**args)
conversation.append({
"type": "function_call_output",
"call_id": item.call_id,
"output": json.dumps(result),
tools=tools,
input=conversation,
print(response.output_text)
Dynamic Model Discovery
Build applications that automatically adapt to newly available models by querying the/v1/models endpoint at startup.
import requests
import os
def discover_models() -> dict[str, list[str]]:
"""Fetch available models and group by provider."""
headers={"Authorization": f"Bearer {os.environ['PERPLEXITY_API_KEY']}"},
resp.raise_for_status()
providers = {}
return providers
def build_fallback_chain(providers: dict[str, list[str]], preferred_order: list[str]) -> list[str]:
"""Build a fallback chain from available models, picking one per provider."""
chain = []
for provider in preferred_order:
if provider in providers and providers[provider]:
chain.append(providers[provider][0]) # Pick first available model
return chain[:5] # Max 5 models in fallback chain
# Discover and build chain
available = discover_models()
print(f"Available providers: {list(available.keys())}")
chain = build_fallback_chain(available, ["openai", "anthropic", "google", "xai", "perplexity"])
print(f"Fallback chain: {chain}")
# Use the dynamic chain
models=chain,
input="Summarize the latest developments in AI regulation worldwide.",
max_output_tokens=1024, # Required if the chain includes an anthropic/* model
print(f"\nModel used: {response.model}")
print(response.output_text[:300])
async function discoverModels(): Promise<Record<string, string[]>> {
return providers;
function buildFallbackChain(providers: Record<string, string[]>, preferredOrder: string[]): string[] {
const chain: string[] = [];
for (const provider of preferredOrder) {
if (providers[provider]?.length) {
chain.push(providers[provider][0]);
return chain.slice(0, 5);
const available = await discoverModels();
console.log(`Available providers: ${Object.keys(available).join(", ")}`);
const chain = buildFallbackChain(available, ["openai", "anthropic", "google", "xai", "perplexity"]);
console.log(`Fallback chain: ${chain.join(" → ")}`);
models: chain,
input: "Summarize the latest developments in AI regulation worldwide.",
max_output_tokens: 1024, // Required if the chain includes an anthropic/* model
console.log(`\nModel used: ${response.model}`);
console.log(response.output_text.slice(0, 300));
The
/v1/models endpoint returns the current list of supported models. Query it at application startup or cache it with a TTL to stay current as new models are added.Next Steps
Agent API Models
Full list of available models, capabilities, and pricing.
Model Fallback
Deep dive into fallback chain configuration and behavior.
Model Comparison Example
CLI tool for benchmarking models side-by-side.
Effort levels
Use effort levels like
low for optimized defaults.
