What you will build
This monitor watches the Perplexity API changelog, pricing guide, and Agent API quickstart for releases, deprecations, pricing changes, and changes to parameters or endpoints. Close your terminal after creating it and read the results later.This example uses three Page targets without a webhook. Use webhooks to receive change notifications without polling for results.
Prerequisites
Use Bash, cURL, and jq, and a Perplexity API key with enough credits for recurring checks. Review Monitor API pricing before starting. API organizations requiring zero data retention cannot create, resume, or manually run monitors.Set up your API key
Use a secret manager or configure your shell to avoid saving the key in history. ReplaceYOUR_API_KEY with your Perplexity API key and run the following commands in the same shell.
Create the monitor
Creation makes the first run due immediately and leaves daily checks active. The run starts asynchronously. Pause the monitor when your trial is finished. The target URLs identify the pages to check. The goal asks the judge to keep substantive API changes and ignore cosmetic ones. To monitor other pages, change the name, URLs, and goal to match the pages and changes you care about.id from your own response into the prompt below; the remaining commands act on the monitor you supply.
The first run and later checks
The first run saves a baseline for each page it successfully reads and reports no page changes for those pages. Existing content becomes part of the baseline. Later checks compare each page with its saved state. The judge assesses detected changes against the goal; an empty result can mean the pages did not change or no detected changes were kept. See the first Page run for baseline behavior.Check the monitor’s status
Retrieve the saved monitor to confirm its goal, targets, and schedule. The create response starts asynchronous work; it does not contain a finished result.status: active means scheduled checks are enabled, while status: paused means they are stopped. Use current_run_id to see whether a run is queued or running, last_run for the last finished run, and next_run_at for the next scheduled check. Fields that do not apply are omitted.
If the monitor is paused unexpectedly, inspect pause_reason before resuming it. See automatic pausing for causes and recovery steps.
Read the findings
Read the run history after creation. This GET request retrieves stored work and does not trigger another page check.queued or running, repeat the same read-only request later.
Check each run’s status before reading its findings:
succeeded: Readchanges[]and inspectcountsandtarget_errors. An emptychangesarray is expected for the first successful baseline and can also occur on later checks when no relevant changes are kept. Checktarget_errorsbefore treating an empty result as a successful check of every page.failedorskipped: Read the run’serror. Do not count it as a successful check.queued,running, or an unknown status: Do not treat the run as finished.
type: page_change, a source url, a stable id, and a confidence score. It includes previous_fetched_at and fetched_at for the compared snapshots, and a diff of normalized page text. The page title may also be included.
The diff contains unified text plus added_lines, removed_lines, and truncated. The unified diff is limited to 24 KiB (24,576 UTF-8 bytes). Truncation keeps complete lines where possible; an oversized line can be shortened at a UTF-8 character boundary. The line counts still describe the full diff.
This diff shows a quickstart changing from presets to effort levels:
confidence score ranges from 0 to 1.
Receive results with webhooks
To receive notifications, add a public HTTPS receiver that you control. See webhook notifications for configuration, delivery, and signature verification.Run a check now
After the first run finishes, you can request another check without waiting for the daily schedule. A manual run can incur usage costs just like a scheduled run.202 response means the run is queued. Read its result through run history. If another run is already queued or running, follow its current_run_id instead; see Run now for response handling.
Pause when finished
Pause the monitor to stop scheduled checks while retaining its state and saved history. A queued run is cancelled; a run already in progress can finish.status: paused. You can also repeat the earlier GET monitor request to verify its saved status.
Example response (excerpt):
Optionally delete it
Deletion also removes run history and saved state. Export any findings you need before executing this command.deleted: true in the response. Do not delete the monitor if you still need its history for review.
Example response:
